Solids
Solids are closed volume of surfaces that can take any shape. Solids are three-dimensional entities that can be used in automatic tetra and solid meshing.
- Bounding Surface
- A bounding surface defines the outer boundary of a single solid.
- Fin Surface
- A fin surface has the same solid on all sides, that is, it acts as a fin inside of a single solid.
- Full Partition Surface
- A full partition surface defines a shared boundary between one or more solids.
When the create mode is set to FE geometry, the output is FE geometry with element tessellation.
