Release Degrees of Freedom
Use the Stiffener Mesh: Pins tool to edit and release degrees of freedom.
You can select a single element at a time and review or edit the released degrees of freedom at node A and node B.
View new features for HyperWorks 2022.
Use the CAD Properties tool to generate PSHELL properties and Beam properties as well as material solver realization.
Use the Beam Sections tool to create and edit standard beam sections, cross beam sections, and HyperBeam sketches.
Use Stiffener Mesh: Create tool to create 1D elements as shell stiffeners from orphan lines representing trailing edges.
Use the Stiffener Mesh: Orient tool to define bar2 orientation vectors or orientation nodes.
Use the Stiffener Mesh: Offset tool to manually set offsets or adjust beams on plates.
Use the Stiffener Mesh: Review tool to plot area moments of inertia and stiffness.
Use the Create tool to create 2D elements and surfaces from 1D beams.
Explore the GeoD user interface.
ON THIS PAGE
ON THIS PAGE
