Create Section and Material Properties
Use the CAD Properties tool to generate PSHELL properties and Beam properties as well as material solver realization.
From the Marine ribbon, click the CAD
Properties tool.
Figure 1. -
Select parts.
These parts should hold the following metadata:
- Plate_T
- Thickness value for panels parts
- Material
- Reference to a material entity
- BeamSection
- Reference to a beamsection entity for Stiffener Parts
On the guide bar, click
to define the material card image and how properties
are updated and applied.
On the guide bar, click one of the following:
- Save changes and stay in
the tool
- Save changes and close the
tool
FE data is applied to your selection.
