Edit Mesh Type and Mapping Method
Use the General 2D Mesh: Face Edit tool to edit the mesh type and mapping method of individual surfaces.
View new features for HyperWorks 2022.
Edit the Parameter and Criteria files and define mesh controls using the Mesh Controls Browser.
1D mesh that allows accurate testing of connectors, such as bolts, and similar rod-like or bar-like objects that can be modeled as a simple line for FEA purposes.
A surface mesh or "shell mesh" represents model parts that are relatively two-dimensional, such as sheet metal or a hollow plastic cowl or case.
Use the General 2D Mesh tool to create 2D meshing with various algorithms.
Use the BatchMesher tool to perform geometry feature recognition, cleanup and automatic meshing in batch mode for given CAD files.
Use the CFD 2D Mesh tool to generate hybrid grids containing hexa/penta/tetra elements in the boundary layer and tetra elements in the core or fare field.
Use the Panel Mesh tool to generate and edit mapped panel mesh.
Use the Panel Mesh: Create tool to create a surface mesh and remesh elements.
Use the Panel Mesh: Density tool to edit element density and size along surface edges.
Use the Panel Mesh: Biasing tool to apply linear, exponential, or bellcurve biasing to individual edges of a surface, and edit the elements size distribution.
Use the Rigid Body Mesh tool to create a quick mesh to represent the topology of a rigid object.
Automatically generate a mesh at the midplane location, directly from the input geometry (components, elements, solids or surfaces), without first creating a midsurface.
Use the Feature Edges tool to create and edit mesh controls on an edge.
The Rebuild tool streamlines the process of remeshing existing meshes to generate a new mesh with good quality and flow. The rebuild mesh functionality utilizes the same parameter and criteria files used by BatchMesher to define the quality criteria and relevant mesh parameters. This algorithm saves significant time over the traditional automesh and quality correction approach.
Adaptive wrap meshing is a useful utility to get a clean, water tight shell mesh out of 2D mesh containing several intersecting parts and small gaps which do not need to be modeled.
EM Lattice meshing is a method to create an axis-parallel mesh for 2D and 1D geometry input.
Shrink wrap meshing is a method to create a simplified mesh of a complex model when high-precision models are not necessary, as is the case for powertrain components during crash analysis.
Create facets out of a scanned data set or node cloud data.
Bulkheads are design enablers that provide localized performance benefits for multiple design attributes such as NVH, Safety, and so on. When their position and thickness are precisely designed, bulkheads can reduce mass and increase performance as they eliminate up-gauging of entire part(s). Typically, bulkheads are welded on one side and bonded with a structural adhesive on the other side and can be incorporated even during the late stages of the product design cycle.
Doublers are design enablers that provide localized performance benefits for multiple design attributes such as NVH, Safety, and so on. When their position and thickness are precisely designed, doublers can reduce mass and increase performance as they eliminate up-gauging of entire part(s). Typically, doublers are typically welded on one side and bonded with structural adhesive on the other side and can be incorporated even during the late stages of the product design cycle.
Volume mesh or "solid meshing" uses three-dimensional elements to represent fully 3D objects, such as solid parts or sheets of material that have enough thickness and surface variety that solid meshing makes more sense than 2D shell meshing.
Explore the GeoD user interface.
to define surface mesh options.
In the case of Map as Triangle- Tria, you can change the corner (anchor) when selecting points. After selecting the initial three points, a fourth click updates the corner. Or, the anchor point can be dragged and placed in a new location based on requirement.
