FE geometry is topology on top of mesh, meaning CAD and mesh exist as a single entity. The purpose of FE geometry
is to add vertices, edges, surfaces, and solids on FE models which have no CAD geometry.
Manage all of the IDs for the entities that you create, and define ID ranges for all of the entities in each Include
file in relation to the full model in order to avoid ID duplication.
Perform automatic checks on CAD models, and identify potential issues with geometry that may slow down the meshing
process using the Verification and Comparison tools.
Properties define various physical and mathematical characteristics of parts such as sheet metal, extruded, and simplified
representations of parts. The assignment and unassignment of properties have a specific set of rules based on the
solver interface being used.
Materials definitions like properties quantitatively define physical characteristics. Many definitions exist like
isotropic, anisotropic, and orthotropic and other material laws that represent steel, plastics, composites, etc. The
assignment and unassignment of materials have a specific set of rules based on the solver interface being used.
Systems are available for assignment to properly control the orientation of entities like loads, transformations of
parts, model has degrees of freedom for movement during simulation among many other applications.
Use the Auto Contacts tool to determine contact interfaces between selections of components or elements. Based on
the user-specified options like proximity tolerance, surface creation method, main surface type, and secondary type,
the tool generates contacts based on set segments or node and element combinations.
Define physical and mathematical characteristics of parts.
Property Assignment
Properties define various physical and mathematical characteristics of parts such as sheet metal, extruded, and simplified representations of parts. The assignment and unassignment of properties have a specific set of rules based on the solver interface being used.
Material Assignment
Materials definitions like properties quantitatively define physical characteristics. Many definitions exist like isotropic, anisotropic, and orthotropic and other material laws that represent steel, plastics, composites, etc. The assignment and unassignment of materials have a specific set of rules based on the solver interface being used.
System Assignment
Systems are available for assignment to properly control the orientation of entities like loads, transformations of parts, model has degrees of freedom for movement during simulation among many other applications.
