Generate Contacts Automatically
                     Use the Auto Contacts tool to determine contact interfaces between selections of         components or elements.  Based on
                        the user-specified options like proximity tolerance,         surface creation method, main surface type, and secondary type,
                        the tool generates contacts         based on set segments or node and element combinations.
