Apply Scale Factors to Shapes
Apply a scale factor to change to the magnitude of the morphed shape.
View new features for HyperWorks 2022.
Morph constraint entities restrict the movements of nodes or force compliance with dimensional requirements during morphing. These constraints are always valid for all available morphing approaches.
Use the Free tool to morph mesh by moving nodes, faces, edges, and shapes or by mapping to geometry.
Use the Proximity tool to morph mesh using a simple distance or perturbation value around selected nodes, faces, edges, or shapes.
Morph volume entities are highly deformable six-sided prisms which surround a portion of the FE mesh, and can be used to manipulate a mesh by manipulating the shape of the morph volume.
Shapes are collections of perturbations from the initial configuration of the FE mesh before the morph.
Create and apply morphing shapes.
Delete selected shapes.
Record node movements using other HyperWorks tools and save them as a shape.
Animate selected shapes.
Convert a shape to node perturbations, handle perturbations, an mvol shape, forces, temperatures, pressures, or displacements.
Import saved shapes from a file.
Export selected shapes.
Domain entities divide the model into different domains during morphing.
Handle entities control the shape of domains during morphing.
Symmetry entities define planes of symmetry within a model so that morphs can be applied in a symmetric fashion.
Undo all morphs and return to the original state of the model.
Explore the GeoD user interface.
