FE geometry is topology on top of mesh, meaning CAD and mesh exist as a single entity. The purpose of FE geometry
is to add vertices, edges, surfaces, and solids on FE models which have no CAD geometry.
The Report Browser is used to create, execute, and export Document and Presentation
reports.
From the menu bar, click Report to open the Report Browser.
The Report Browser has three sections:
Toolbar
The Report Browser toolbar allows you to perform following actions:
Tree Area
The Report Tree Area allows you to add items and create a report tree structure,
which also can be referred to as a table of contents.
Entity Editor
In a Report, each entity has associated properties, which directly or indirectly
define the inputs. These properties can be accessed from the Entity Editor in the
Report tab.
Figure 3.
Filepath Storage
Select the file path information storage type.
Available options are
Absolute
If selected at Report level, then absolute paths are shown
in all items or modules wherever there is a file path.
Relative
If selected at Report level, then all the paths in items or
modules are shown relative to Working Directory.
Export File Formats
Report supports the following input file templates formats:
DOCX
DOCM
PPTX
PPTM
The supported output file formats are as follows:
DOCX
DOCM
PPTX
PPTM
PDF, ODT, and ODP
Note: These formats are available
only with a word processing application.
HTML
Open Report file are export
Select the option to open the report file after export.
