Find and Search for Tools
Quickly find and open the tools, panels, and browsers that are available from the ribbons or from the Utility Browser, as well as create entities and solver cards.
View new features for HyperWorks 2022.
Explore the HyperWorks user interface.
View controls enable you to control the view and display of your model in the modeling window.
Select and deselect entities to modify with other HyperWorks tools. Selected entities are outlined to indicate their selection state.
Translate, rotate, and align the model.
Use the Measure tool to measure length, angles, radii, areas, volumes, centers of gravity, and bounding boxes.
Learn how to manipulate entities in HyperWorks.
Undo and redo actions performed in HyperWorks.
Default keyboard shortcuts and mouse controls.
Explore the GeoD user interface.
Selecting an entity adds the entity to the model and opens the corresponding Entity Editor. Entities are grouped under the Create heading.
