Aeroelastic Analysis
Aeroelastic analysis is the study of the deflection of flexible aircraft structures under aerodynamic loads, wherein the deformation of aircraft structures in turn affect the airflow.
Figure 1. Aeroelasticity Overview
The interaction between Elastic forces and Aerodynamic forces can be analyzed, as part of the Static Aeroelasticity solution.
