/BOX/RECTA
Block Format Keyword Describes a rectangle box for entities selection.
/BOX/RECTA/box_ID/unit_ID | |||||||||
box_title | |||||||||
N1 | N2 | skew_ID | |||||||
Xp1 | Yp1 | Zp1 | |||||||
Xp2 | Yp2 | Zp2 |
box_ID | Box identifier. (Integer, maximum 10 digits) |
unit_ID | Unit Identifier. (Integer, maximum 10 digits) |
box_title | Box title. (Character, maximum 100 characters) |
N1 | Node identifier. (Integer, maximum 10 digits) |
N2 | Node identifier. (Integer, maximum 10 digits) |
skewID | Fixed skew identifier. Only used to
align box edges with the skew direction. (Integer, maximum 10 digits) |
Xp1 | X coordinate of point
P1. (Only used if N1 is not
defined). (Real) |
Yp1Y | Y coordinate of point
defined). (Real) |
Zp1 | Z coordinate of point
defined). (Real) |
Xp2 | X coordinate of point
P2. (Only used if N2 is not
defined). (Real) |
Yp2 | Y coordinate of point
defined) (Real) |
Zp2 | Z coordinate of point
defined) (Real) |
- A box (RECTA) defined above is used for:
