/BOX/SPHER
Block Format Keyword Describes a spherical box for entities selection.
/BOX/SPHER/box_ID/unit_ID | |||||||||
box_title | |||||||||
N1 | Diameter | ||||||||
Xp1 | Yp1 | Zp1 |
box_ID | Box identifier. (Integer, maximum 10 digits) |
unit_ID | Unit Identifier. (Integer, maximum 10 digits) |
box_title | Box title. (Character, maximum 100 characters) |
N1 | Node identifier. (Integer, maximum 10 digits) |
Diameter | Diameter of sphere. (Real) |
Xp1 | X coordinate of point
P1. (Real) |
Yp1 | Y coordinate of point
P1. (Real) |
Zp1 | Z coordinate of point
P1. (Real) |
- A box (SPHER) defined above is used for:
