/GRTRIA/GENE
Block Format Keyword Generate a group of triangles (/TRIA) by listing the first and last element IDs in the range.
/GRTRIA/GENE/grtria_ID/unit_ID | |||||||||
grtria_title | |||||||||
first_ID1 | last_ID1 | first_ID2 | last_ID2 | first_ID3 | last_ID3 | first_ID4 | last_ID4 | first_IDn | last_IDn |
grtria_ID | Group
unit_ID | Unit Identifier (Integer, maximum 10 digits) |
grtria_title | Group title (Character, maximum 100 characters) |
first_ID1, last_ID1,...first_IDn, last_IDn | List of first and last
triangle identifiers (Integer) |
