/GRTRIA/PART
Block Format Keyword Group of triangles (/TRIA) is built according to PART identifiers which are provided.
| /GRTRIA/PART/grtria_ID/unit_ID | |||||||||
| grtria_title | |||||||||
| item_ID1 | item_ID2 | item_ID3 | item_ID4 | item_ID5 | item_ID6 | item_ID7 | item_ID8 | item_ID9 | item_ID10 |
| grtria_ID | Group
| unit_ID | Unit Identifier (Integer, maximum 10 digits) |
| grtria_title | Group title (Character, maximum 100 characters) |
| item_ID1, item_ID2,..., item_IDn | List of parts
identifiers (Integer) |
- The 2D solid triangles groups cannot contain 2D solid quadrangles (use /GRQUAD instead).
- If item_ID is a negative number, the item number is deleted from the group.
