Solid (Schelkunoff) - Legacy
This option defines a shield using the solid (Schelkunoff) model.
![](../../../../../../images/feko/user_guide/editfeko_cards/dialog_sh1.png)
Figure 1. The SH - Cable shield definition dialog, set to Solid (Schelkunoff).
Parameters:
- Use legacy shields definitions
- Unselect this option to define a layered shield using shield definitions from an SD card.
- Metallic material
- PEC
- Select this option to set the shield of the filaments to PEC.
- Material label
- The label of the metallic material (as defined in the DI card) to be used for the shield.
- Coating
- Material label for coating
- The label of the dielectric (as defined in the DI card) to be used as the coating for the cable.
- Thickness of layer for coating
- Define the thickness of the dielectric coating.
