Shield Layer Combinations
When specifying a cable shield, you need SD cards to specify the shield layer impedance or shield layer admittance. Several combinations of SD cards are supported when defining the shield layer impedance and shield layer admittance for a cable shield (SH card).
Table 1. Supported shield layer combinations when specifying the impedance and admittance for a shield layer.
Impedance Definition (Zt + Zs) Admittance Definition (Yt)
Solid (Schelkunoff) Not applicable
Braided (Kley) Same as impedance definition
Transfer capacitance
Define properties
Braided (Tyni) Same as impedance definition
Define properties
Braided (Vance) Same as impedance definition
Define properties
Braided (Demoulin) Same as impedance definition
Define properties
Define properties Same as impedance definition
Define properties
