Braided (Vance) - Legacy
This option defines a braided shield using the Vance model.
Figure 1. The SH - Cable shield definition dialog, set to Braided (Vance).
Parameters:
- Use legacy shields definitions
- Unselect this option to define a layered shield using shield definitions from an SD card.
- Number of carriers (m)
- The number of the carriers in the braided shield.
- Weave angle (degrees)
- The weave angle of the shield.
- Number of filaments (n)
- The number of filaments in each carrier.
- Diameter (d)
- The diameter of the filament.
- Metallic material
- PEC
- Select this option to set the shield of the filaments to PEC.
- Material label
- The label of the metallic material (as defined in the DI card) to be used for the shield.
- Coating
- Material label for coating
- The label of the dielectric (as defined in the DI card) to be used as the coating for the cable.
- Thickness of layer for coating
- Define the thickness of the dielectric coating.
