Model ElementDcurve defines a deformed curve in MotionSolve.
Class Name
Dcurve, DeformableCurve
It is used in the definition of a Point-to-Deformable-Curve constraint (PTDCV)
Attribute Summary
Name |
Property |
Modifiable by
command? |
Designable? |
id |
Int () |
label |
String () |
end_type_left |
Enum ("NATURAL
PARABOLIC PERIODIC CANTILEVER", default="NATURAL") |
end_type_right |
Enum ("NATURAL
markers |
Reference (Marker,
count=0) |
Yes |
u_span |
Double
(1.0) |
Yes |
lambda_left |
Double () |
lambda_right |
Double () |
tension |
Double () |
Yes |
u_closed |
Bool () |
Usage
DeformableCurve (markers=list, u_span=double, optional_attributes)
Attributes
- markers
- List of references to existing Markers
- Specifies the Marker whose origins define this deformable
curve.
- The markers attribute is mandatory.
- u_span
- Double
- Specifies the parametric span of the curve. The curve parameter, u,
is limited to operating in the range: -u_span/2 ≤ u ≤
u_span/2
- The u_span attribute is mandatory. A good value for
u_span is 1.0.
- u_span > 0
- id
- Integer
- Specifies the element identification number. This number must be unique among all the
DeformableCurve objects in the model.
- This attribute is optional. MotionSolve will automatically
create an ID when one is not specified.
- Range of values: id > 0
- label
- String
- Specifies the name of the DeformableCurve object.
- This attribute is optional. When not specified, MotionSolve will create a label for you.
- end_type_left
- String
- Defines the end type condition for this deformed curve on the left end of the curve.
end_type_left must be one of the following 4 strings:
- "NATURAL"
- "PARABOLIC"
- "PERIODIC"
- "CANTILEVER"
- This attribute is optional. When not specified, it defaults to
"NATURAL".
- end_type_right
- String
end_type_right must be one of the following 4 strings:
- "NATURAL"
- "PARABOLIC"
- "PERIODIC"
- "CANTILEVER"
"NATURAL".
- lambda_left
- Double
- This parameter is only applicable for the CANTILEVER type end
condition. lambda_left is a real valued parameter in the interval
[0, 1] that controls the left end condition for CUBIC spline interpolation.
- A value of 0 implies NATURAL end condition
- A value of 1 implies PARABOLIC end condition
- This attribute is optional. When not specified, it defaults to 0
("NATURAL").
- lambda_right
- Double
condition. lambda_left is a real valued parameter in the interval [0,
("NATURAL").
- u_closed
- A Boolean value (True or False) that determines
whether the markers that define the curves are closed or not.
This example shows a simple definition of a deformed
curve.
# Define the markers whose origins will form the closed deformable curve
mvec = =[m1091, m2091, m3091, m4091, m5091, m6091, m7091, m8091, m9091, m1091]
# Define the deformable curve - with end type = NATURAL
dc1 = DeformableCurve (markers=mvec, u_span=1.0)
- See Properties for an
explanation about what properties are, why they are used, and how you can extend these.
- For a more detailed explanation about Dcurve,
see Reference: Deform Curve.
