Model ElementSforce defines a force or torque acting between two
Markers.
The force or torque is characterized by a magnitude and a direction. The direction is pre-defined
dependent on TYPE and ACTIONONLY. For details,
see the Comments
in the Force: Two Body Scalar model statement. The magnitude may
be defined using a function expression, a user-defined subroutine, a Python script or a MATLAB script. The magnitude can be a
function of any system state and time.
Attribute Summary
| Name |
Property |
Modifiable by
command? |
Designable? |
| id |
Int
| label |
Str
| i |
Reference (Marker) |
Yes |
Yes |
| j |
Yes |
Yes |
| type |
Enum
("TRANSLATION ROTATION") |
| actiononly |
Bool
Yes |
| function |
Function ("SFOSUB") |
Yes |
| routine |
Routine () |
| active |
Bool
Yes |
Declaration
#1. Force or torque magnitude defined in a MotionSolve expression
Sforce (i=objMarker, j=objMarker, type=string, function=expressionString, routine=string, optional_attributes)
#2. Force or torque magnitude defined in a compiled DLL
Sforce (i=objMarker, j=objMarker, type=string, function=userString, routine=string, optional_attributes)
#3. Force or torque magnitude defined in a Python/Matlab script
Sforce (i=objMarker, j=objMarker, type=string, function=userString, routine=functionPointer, optional_attributes)
Attributes
MotionSolve expression.
- i
- Reference to an existing Marker object.
- Specifies the marker at which the force and moment is applied. This is
designated as the point of application of the force.
- The i attribute is mandatory.
- j
- Specifies the marker at which the reaction force and moment is applied.
This is designated as the point of reaction of the force.
- The j attribute is mandatory.
- type
- String
- Specifies the type of Sforce being defined. Select
from "TRANSLATION" and "ROTATION".
- "TRANSLATION": The element applies a force
between the two markers. No torque is applied.
- "ROTATION": The element applies a torque
between the two markers. No force is applied.
- function
- String defining a valid MotionSolve
expression
- Specifies the MotionSolve expression that
defines the VARIABLE. Any valid run-time MotionSolve expression can be provided as
input.
- A constant magnitude Sforce can be specified as a
constant expression.
- The function attribute is mandatory.
Force or torque magnitude defined in a compiled DLL.
- i
- j
- type
- String
- function
- String defining a valid user function MotionSolve expression.
- The list of parameters that are passed from the data file to the user
defined subroutine where the Sforce is defined.
- routine
- String
- Specifies an alternative name for the user subroutine. The name consists
of two pieces of information, separated by "::". The first is the
pathname to the shared library containing the function that computes the
response of the user-defined Variable. The second is
the name of the function in the shared library that does the
computation.
- An example is: routine="/staff/Altair/engine.dll::mySforce"
- "/staff/Altair/
engine.dll is the DLL
- "mySforce" is the
function within this DLL that performs the calculations
- The attribute routine is optional.
- When not specified, routine defaults to
SFOSUB.
Python function.
- i
- j
- type
- String
- function
- routine
- Pointer to a callable function in Python.
- An example is: routine=mySforce.
- mySforce is a Python function or method that can be
called from wherever the model resides.
SFOSUB.
Optional attributes - Available to all variants.
- id
- Integer
- Specifies the element identification number. This number must be unique
among all the Variable objects in the model.
- This attribute is optional. MotionSolve will
automatically create an ID when one is not specified.
- Range of values: id > 0
- label
- String
- Specifies the name of the Variable object.
- This attribute is optional. When not specified, MotionSolve will create a label for you.
- actiononly
- Boolean
- Select from "True" and "False".
- "True": The element applies a force/torque on
the I marker but no reaction on the J marker.
- "False": The element applies a force/torque on
the I marker and also a reaction force/torque on the J
marker
- Default value is False.
- active
- Bool
- Select one from True or False.
- True indicates that the element is active in
the model and it affects the behavior of the system.
- False indicates that the element is inactive in
the model and it does not affect the behavior of the system. It
is almost as if the entity was removed from the model, of course
with the exception that can be turned "ON" when
desirable.
- The attribute active is optional. When not specified,
active defaults to True.
Model the example below using the
Python
interface.
#<Force_Scalar_TwoBody
# id = "7"
# type = "TORQUE"
# i_marker_id = "71"
# j_marker_id = "81"
# val_expression = "(SQRT(JOINT(7,2,0,71)**2 + JOINT(7,3,0,71)**2) + 1167)*
# STEP(0.044*WZ(71,72,72),-0.01,0.3,0.01,-0.3) * 0.44"
# Normal force: Fn
Fn = "sqrt (joint(7,2,0,71)**2 + joint(7,3,0,71)**2) + 1167)"
# Coefficient of friction: Mu
Mu = "step (0.044*wz(71,72,72),-0.01,0.3,0.01,-0.3)"
# Friction Torque = Pin_Radius * Fn * Mu
pinRad = "0.44"
fricTorque = pinRad + " * " + Fn + " * " + Mu
# Sforce
sf07 = Sforce (id=7, label= "sfo7", i=m71, j=m81, type="ROTATION", function=fricTorque)
- The table below summarizes the direction of the force or torque that is
applied by an Sforce.
| Type |
ActionOnly |
Direction |
| "TRANSLATION" |
True |
The direction of the force on Marker I is defined by the
unit vector along the z-axis of Marker J. There is no
reaction force on the body containing Marker
J.
| "TRANSLATION" |
False |
unit vector from Marker J to Marker I. The force on Marker
J is equal and opposite.
| "ROTATION" |
True |
The direction of the torque is also defined by the z-axis
of Marker J. There is no reaction torque on the body
containing Marker J.
| "ROTATION" |
False |
The direction of the torque is defined by the z-axis of
Marker J. The z-axis of Marker I and Marker J are required
to always be parallel.
- See Properties for an
explanation about what properties are, why they are used, and how you can extend
these.
- For a more detailed explanation about Sforce,
see Force: Two Body Scalar model
statement.
