Command ElementThe Linear class is a command element that controls the
solver parameters for linear/eigen mode analysis.
Attribute Summary
Name |
Property |
Modifiable by command? |
Designable? |
id |
Int() |
Yes |
No |
label |
Str() |
animation_scale |
Double() |
simulink_mdl |
Bool () |
oml |
Bool () |
matlab |
Bool () |
eigensol |
Bool () |
pinput |
Reference (Pinput) |
poutput |
Reference (Poutput) |
statemat |
Bool () |
nodamping |
Bool () |
kinetic |
Bool () |
cutoff_frequency |
Double (-1) |
pstate |
Reference (Pstate) |
Usage
#1: define a linear command to generate OML state space representation of the model
Linear(simulink_mdl = False, oml = True, matlab = False, statemat =True)
#2: Define a Plant State entity and reference that in the Linear command
Linear(simulink_mdl = False, oml = True, matlab = False, statemat =True, pstate=Pstate(variables=[var1, var2]))
#3: Define Plant Input and Plant Output Linear command
Linear(statemat =True, pinput=Pinput(variables = [var1]), poutput=Poutput(variables = [var2]))
Attributes
- animation_scale
- Double
- Specifies a factor for magnifying the mode
shapes during animation.
- This attribute is optional. MotionSolve automatically sets
animation_scale to 1.0 when it
is not specified.
- simulink_mdl
- Bool
- Specifies whether the A, B, C, and D matrices
that are calculated are to be written out in
Simulink MDL format or not. Select from
True and
False.
- The default is simulink_mdl
= False.
- oml
- Bool
OML format or not. Select from
True and
False.
- The default is oml =
True.
- matlab
- Bool
that are calculated are to be written out to a
file that can be read by MATLAB. Select from
True and
False.
- The default is matlab =
False.
- eigensol
- Bool
- Specifies whether the eigenvalue and
eigenvector data is to be written to an
.eig file. Select from
True and
False.
- The default is eigensol =
False
- nodamping
- Bool
- Specifies whether the linearization solver
should disable damping from all force elements for
the eigenvalue solution.
- The default is False;
damping is considered for the eigenvalue
solution.
- kinetic
- Bool
- Specifies whether the modal kinetic energy
distribution is to be written out to the solver
log file and the *_linz.mrf
output file. Select from
True and
False.
- The default is kinetic =
False
- statemat
- Bool
are to be calculated and written out into a file.
The format of the file is determined by other
attributes. Supported formats are OML, MDL MATLAB, and Simulink. Select
from True and
False.
- The default is statemat =
False
- pinput
- Reference to an existing plant input.
- Specifies a plant input to be used for the
State Space representation of the system.
pinput participates in the B
and D state matrices.
- poutput
- Reference to an existing plant output.
- Specifies a plant output to be used for the
poutput participates in the C
- pstate
- Reference to an existing plant state.
- Specifies a plant state to be used in the
state space representation of the system. A
PlantState defines a list of user-defined states
used in generating a linear representation of a
model about an operating point. The linear
representation is used for both eigenvalue
analysis and state matrix generation.
- cutoff_frequency
- Double
- Specifies the upper bound of the eigenvalues
which are the natural frequency/damping
characteristics of the system.
XML syntax versus
Python for the same
example:
<Param_Linear
anim_scale = "1."
write_simulinkmdl = "NO"
write_matlabfiles = "NO"
write_eig_info = "YES"
write_energy_dist = "YES"
Linear(animation_scale = 1.0, simulink_mdl = False, matlab = False, eigensol = True, kinetic = True)
