Variable
Model ElementVariable defines an algebraic state in MotionSolve.
Class Name
Variable
- An explicit or implicit function of system state and time defined in a MotionSolve expression.
- An explicit or implicit function of system state and time defined in a compiled DLL.
- An explicit or implicit function of system state and time defined in a user-defined script.
Variables are quite versatile and have many different applications in modeling multibody systems. They are used to create signals of interest in the simulation. The signal may then be used to define forces, create independent variables for interpolation into test data, define inputs to generic control elements, and create complex output signals.
Attribute Summary
Name | Property | Modifiable by command? | Designable? |
id | Int () | ||
label | Str () | Yes | |
ic | Double () | Yes | FD Only |
implicit | Bool (False) | FD Only | |
auto_balance | Enum ("DEFAULT UNCONDITIONAL DISABLED PENALTY", default="DEFAULT") | ||
penalty | Double (default=None) | Yes | FD Only |
penalty1 | Double (default=None) | Yes | FD Only |
function | Function ("VARSUB") | Yes | |
routine | Routine () |
Usage
# Defined in a MotionSolve expression
Variable (function=expressionString, optional_attributes)
# Defined in a compiled user subroutine
Variable (function=userString, routine=string, optional_attributes)
# Defined in a Python function
Variable (function=userString, routine=functionPointer, optional_attributes)
Attributes
- function
- String defining a valid MotionSolve expression.
- function
- String defining a valid user function MotionSolve expression.
- routine
- String
- function
- routine
- Pointer to a callable function in Python
- id
- Integer
- label
- String
Examples
- Compute the Kinetic Energy of a rigid body in an expression.
This example demonstrates how to use an EXPRESSION based Reference_Variable to calculate the kinetic energy of a rigid body. In the example below, the ID of the Reference_Variable is 3070. 1011 is a MARKER that defines the center of mass of a rigid body with mass 4kg and principal moments of inertia Ixx=0.006 Kgm2, Iyy=0.005 Kgm2, and Izz=0.004 Kgm2. Reference_Variable 3070 is the total kinetic energy of the rigid body.
This example demonstrates how to use an EXPRESSION based VARIABLE,translationalKE = "0.5*(4*vm(1011)**2" rotationalKE ="0.006*wx(1011)**2+0.005*wy(1011)**2+0.004*wz(1011)**2)" KE = translationalKE " + " rotationalKE totalKE = Variable (function=KE)
- Compute the Kinetic Energy of a rigid body in a Python script.This is the same example solved in the XML section of the description.
# Define the VARSUB, written in Python def VARSUB(id, time, par, npar, dflag, iflag): # Get information from the par array icm = par[0] mass = par[1] ixx = par[2] iyy = par[3] izz = par[4] # get the translational and rotational velocity states vm = VM (icm) w = WXYZ (icm) # Calculate the kinetic energy if iflag: totalKE = 0.0 else: totalKE = 0.5 * (mass*vm**2+ ixx*w[0]**2+ iyy*w[1]**2+ izz*w[2]**2) return totalKE # Define the Variable expr = "User ({id}, 4, 0.006, 0.005, 0.004)".format(id=mrkr3070.id) Variable (function=expr)
- Use an implicit VARIABLE to drive a robot.
See Example 3 in the XML syntax for detailed explanations. Here the Python implementation is explained.
Step-1: Define two algebraic constraints that define the motion of Marker 11.varX = Variable (function="DX(2011)-cubspl(time, 0, 1)", implicit=True, autobalance="DISABLED", label="X-path of end effector") varY = Variable (function="DY(2011)-cubspl(time, 0, 2)",implicit=True, autobalance="DISABLED", label="Y-path of end effector"))
Step-2: Apply the internal force as torques at joints J1 and J2.
Assume that joint J1 is defined with I marker=33, J Marker=44 and joint J2 is defined with I marker=55, J Marker=66expr1 ="VARVAL({vid})".format(vid=varX.id) torque1 = Sforce (i=marker33, j=marker44, type="ROTATION", function=expr1) expr2 ="VARVAL({vid})".format(vid=varY.id) torque2 = Sforce (i=marker55, j=marker66, type="ROTATION", function=expr2)
Step-3: Look at the torques applied at the Joints to size the motors
varX and varY are the two Variables that apply the torques at joint J1 and J2 respectively. You can look at their values by calling the functions VARVAL(varX.id) and VARVAL(varY.id). These can be used to "size" the motors.
- Use a Variable to communicate to MATLAB.
See Example 4 in the XML syntax for detailed explanations. Here the Python implementation is explained.
The plant output may be defined as follows:# Define VARIABLE-12 expr1 ="AY({i}, {j})".format(i=m6565.id, j=m7676.id) var12 = Variable (function=expr1) # Define VARIABLE-13 expr2 ="WY({i}, {j})".format(i=m6565.id, j=m7676.id) var13 = Variable (function=expr2) # Define the Plant Output plantOutput = Poutput (variables=[var12, var13])
- Use a Variable to define a nonlinear relationship in a model.
See Example 5 in the XML syntax for detailed explanations. Here the Python implementation is explained.
Assume that the revolute joint on the steering wheel is defined by I-Marker = m6565 and J-Marker = m7676. The variables defining the steering angle and the steering gear ratio are shown below.# Define the steering angle expr1 ="RTOD*ABS(AZ({i}, {j})".format(i=m6565.id, j=m7676.id) var1 = Variable (function=expr1, label="Steering gear angle in degrees") # Define the steering gear ratio expr2 ="step (varval({v}), 100, 1000, 150, 1500".format(v=var1.id) var2 = Variable (function=expr2, label="Steering gear ratio")
- Use a Variable to define a "soft" constraint.See Example 6 in the XML syntax for detailed explanations. Here the Python implementation is explained.
# Compute the violation from the "set point" for the angle and penalize it expr ="theta({i},{j})-60D".format(i=markerI.id, j=markerJ.id) var = Variable (function=expr, penalty=1000, penalty1=10, label="control force")
Force_Penalty is a more natural way to define the soft constraint.# Compute the violation from the "set point" for the angle and penalize it expr ="theta({i},{j})-60D".format(i=markerI.id, j=markerJ.id) controlForce = Pforce (function=expr, penalty=1000, penalty=10, auto_balance="PENALTY", label="control force")
- See Properties for an explanation about what properties are, why they are used, and how you can extend these.
- For a more detailed explanation about Variable, see Reference: Variable.
