.dens file
The .dens file is an OptiStruct ASCII format results file.
File Creation
This file is created when the OPTI, OS or BOTH formats are chosen and a topology optimization is performed. (See documentation for the I/O Option OUTPUT).
File Contents
Result Description
Density Density results from topology optimizations.
Output is controlled by the I/O Option DENSRES.
File Format
The density file has the following format:
For each iteration, the following header is used:
  iter Iteration Numel
Data
iter
Keyword identifying that the next field is the iteration number.
Iteration
Iteration number.
Numel
Total number of elements in entire model.
  EID Mat_dens
Data
EID
The element identification number.
Mat_dens
The element material density. Non-design elements are assigned a material density of 1.0.
