.#.#.els file
The .#.#.els file is a Patran 2.5 ASCII format results file.
File Creation
This file is created when the Patran format is chosen and linear static analysis is performed. (See documentation for the I/O Option OUTPUT).
File Contents
Result | Description |
Stress | Stress results from linear
static analysis. Output is controlled by the I/O Option STRESS (or ELSTRESS). |
- One such file is created for each subcase at each iteration where the I/O Option RESULTS requests analytical results to be output.
- The first # in the file name is the iteration number.
- The second # in the file name is the user-defined Subcase ID.
