.dvgrid file
The .dvgrid file is an OptiStruct ASCII format results file.
File Creation
This file is only created when an analysis is performed. Creation of this file is controlled by the I/O Option OUTPUT.
File Contents
The file contains shape variable definitions for the displacements or eigenvectors resulting from linear static, inertia relief, or normal modes analyses.
File Format
DESVAR and DVGRID definitions are provided for each linear static subcase and for each calculated normal mode.
Output for linear static subcases begins with a header in the following format:
$ DESVAR and DVGRIDs for static load case        subcase_id
where:
subcase_id
User-defined subcase identification number.
Output for calculated normal modes begins with a header in the following format:
$ DESVAR and DVGRIDs for eigenvalue load case subcase_id, Mode Number mode_number
where:
subcase_id
mode_number
Mode number.
The DESVAR and DVGRID definitions are formatted as per the Bulk Data descriptions.
