The .spcf file is an OptiStruct
ASCII format results file.
File Creation
Creation of this file is controlled by the SPCFORCES I/O Option.
File Contents
| Result |
Description |
| Single-point force of
constraint |
constraints for linear static analysis. |
File Format
The SPC reaction force file has the following format:
| For each iteration, the following header is
used: |
iter |
Iteration |
Numlds |
- Data
- Description
- iter
- Keyword denoting the beginning of a new iteration.
- Iteration
- The iteration number.
- Numlds
- The number of subcases for which this output is created.
| Each iteration section is divided up by subcase.
Output for each subcase starts with a line in the following
format: |
Id |
Number_of_nodes |
Frequency |
SPCF:Spc_id(Datatype) |
subcase_label |
- Data
- Description
- Id
- The output identification number for the subcase. This is not the same
as the subcase ID used in the input data
- Number_of_nodes
- The number of nodes for which this output is requested.
- Frequency
- Is 1.0 for static analysis.
- SPCF
- Keyword declaring SPC-force information
- Spc_id
- The SID for SPC's referenced by this subcase.
- Datatype
- Keyword indicating the type of subcase involved.
- (LOAD) declares data is for a linear static subcase.
| SPC-force information is then provided, for each
node, in the following format: |
Node_id |
x-force |
y-force |
z-force |
x-moment |
y-moment |
z-moment |
- Data
- Description
- Node_id
- The node identification number.
- x-force
- The x-translational component of the force at the node.
- y-force
- The y-translational component of the force at the node.
- z-force
- The z-translational component of the force at the node.
- x-moment
- The x-rotational component of the force at the node.
- y-moment
- The y-rotational component of the force at the node.
- z-moment
- The z-rotational component of the force at the node.
- The I/O Option Previously Supported Results controls
the frequency of output for analytical results during an optimization.
