.flst file
An OptiStruct XML format file.
File Creation
This file is created when the -inventory
run option is used.
File Contents
The .flst file contains a list of all input files needed for the run.
In this file, the OptiStruct input files are referenced
by ‘input
’ and all other files listed in ASSIGN
or RESTART are referenced by ‘data’
<results_catalog>
<input name="file1.fem"/>
<input name="C:/directory1/file2.fem"/>
<data name="../directory2/test_dir/test_file_name.h3d"/>
</results_catalog>
- This file is only output when the
-inventory
run option is used. - Refer to
-inventory
in Run Options for more information.
