_s#_s.trn file
An OptiStruct ASCII format results file.
File Creation
This file is only created for transient response subcases when the OUTPUT, HGTRANS option is used along with the RESULTANT option.
File Contents
Result Description
Section forces and moments Section force and moment results from transient analysis.
File Format
Time FX FY FZ MX MY MZ F M
Where,
FX, FY, FZ
The X, Y, Z components of section forces, respectively.
MX, MY, MZ
The X, Y, Z components of section moments, respectively.
F, M
The magnitudes of section force and section moment, respectively.
  1. The ‘#’ in the file name is the user-defined subcase ID from which these results are obtained.
  2. The _tran.mvw HyperView script file automatically creates plots for the results contained in this file.
