_des.h3d file
A compressed binary file, containing both model and result data. It can be used to post-process results in HyperView or when using the HyperView Player.
File Creation
The _des.h3d file is created when the H3D format is chosen (I/O Option OUTPUT), and an optimization run is performed.
File Contents
The _des.h3d file contains node and element definitions in addition to the following results.
- Result
- Description
- Density
- Density results from topology optimizations.
- Shape
- Shape results from topography or shape optimizations.
- Thickness
- Thickness results from size and topology optimizations.
- Material Type
- Material type results from multiple material topology optimizations.
- The material type would be shown as 0, if the density of each material is less than 0.3.
