.monitor file
An OptiStruct ASCII format results file.
File Creation
This file is created by default for any nonlinear run.
File Contents
This file contains, for each nonlinear subcase, a table of the load increments, cutback information, number of iterations for each load increment, and the values of time increments and cutbacks and displacement results.
These displacement results pick the maximum value across all degrees of freedom, by default. Specific Grid and degree of freedom at which displacement results should be printed can be identified using the GRID and DOF parameters on the NLMON Bulk Data Entry.
File Format
![](../../../images/solvers/monitor_output.png)
Name | Content |
SUBCASE SID | Identification number of the Subcase for which the information is printed. |
INCREMENT |
ITER |
TIME |
MONITOR |
