Review Loadcase Options
Description of Review All Loadcases Options.
Dynamic Event Loadcases
Add () or Delete () loadcases.
Figure 1 shows the table for a dynamic event.
Columns of the table:
ID
Load Step ID
Name
Name of the loadstep
Load Directions
Define directions and respective scale factor for the loadstep.
Load Type
Type of Load
Source
Load definition source
Time Length
Load application time length in seconds(s)
Export
Select required load step to export
Static Event
Figure 2 is the table for a static event.
Amplitude
Load amplitude value
All other columns are same as dynamic event table.
Thermal Event
Figure 3 is the table for a thermal event.
Figure 3.
