Browsers supply a great deal of view-related functionality by listing the parts of a model in a tabular and/or tree-based
format, and providing controls inside the table that allow you to alter the display of model parts.
FE geometry is topology on top of mesh, meaning CAD and mesh exist as a single entity. The purpose of FE geometry
is to add vertices, edges, surfaces, and solids on FE models which have no CAD geometry.
Tools and workflows that are dedicated to rapidly creating new parts for specific use cases, or amending existing
parts. The current capabilities are focused on stiffening parts.
Assess the squeak and rattle risks by viewing the results from the squeak and rattle
analysis.
For Risk Assessment, you will need a Result file from
analysis in OptiStruct containing relative displacement
output for all defined E-Lines.
In Risk Assessment, the results from three types of events
are reviewed: Dynamic, Static, and Thermal. Evaluation of rattle and squeak E-Lines are done separately.
Rattle Evaluation
The automatic assessment allows the understanding of the rattle phenomena using the following:
Squeak Evaluation
The automatic assessment allows the understanding of the squeak phenomena using the following:
