Perform Risk Assessment
From the Analyze group, select the Risk
Assessment tool.
Select a result file and which loadcase to evaluate.
- For a Static Event load- .h3d file.
- For a Dynamic Event load- .pch file.
- Click Plot to visualize results.
- Click to clear the existing plot.
- Select multiple results at a time and control how these are visualized using .
- Optional:
Review the summary of all E-Lines in the model for the active loadcase and
result file by clicking .
If loading results from additional result files and loadcases, these will be appended to the Summary Table. The active loadcase(s) will be visible in the Bar-Plot. For easy comparison between load-cases or design iterations, select multiple and these will all be visualized.
A summary of all E-Lines in the model for all result files and loadcases loaded in session are available for easy comparison and Report creation.
- Optional:
active loadcase and result file by expanding .
If you are loading results from additional result files and load cases, these will be appended to the Summary Table.
For easy comparison between load-cases or design iterations, select multiple and these are visualized.
- Toggle active load-case to update Bar plot.
