Rattle Evaluation
The automatic assessment allows the understanding of the rattle phenomena using the following:
- Relative Displacement (X, Y, Z, MAG)
- Relative movement between the two components along the Evaluation lines.
This is available in all directions:
- Z defines the Gap Direction
- X-Y defines the Contact Plane
- Dynamic Tolerance
- Upfront Risk or No Risk where the relative displacement is compared to the actual Gap and tolerance values.
- Contact Risk Index
- If there are risks for the rattle, these can be further quantified using CRI based on the stiffness of the interface. A soft interface has a lower risk for an audible Rattle than a hard interface.
