View new features for HyperWorks 2022.2.
Use the Section Cut tool to cut planar or spherical sections through a model.
Use the Contour tool to create contour plots of a model and graphically visualize the analysis results.
Learn about creating and managing contour plots.
A contour plot generates color bands on the model, based on the values found in the results file.
Layers allow you to display a contour for a specified element layer when a layer definition is available for an element.
The Value filter available in the Contour panel allows you to specify threshold criteria for processing results only in a specific range.
Composites post-processing is enhanced in HyperView with the reorganization of ply results as layers.
After a contour plot has been applied in the Contour panel, the Cache feature will become active and allow you to add the currently active contour result to an internal cache.
Mid-side nodes refers to the nodes in between the corner nodes of the 2nd order elements.
Use the Iso tool to display single iso values (iso surfaced for solids or iso line for shells) dependent on results data.
Use the Vector tool to set options for a vector plot.
Use the Tensor tool to view tensor plots of stress and strain directions and magnitudes for various solvers from elemental values.
Refresh Results is a convenient way to quickly refresh a result plot (contour, vector, tensor, or iso) whenever the display changes.
The Edit Legend dialog allows you to change the legend properties.
You can edit the contour, vector, or tensor plot legend in the graphics area.
Results in some analysis types come as complex numbers.
A listing of results that are computed in HyperView.
Nodal averaging of elemental results at a node refers to the average of all the element corner results passing through that node.
The averaging options allow you to limit the averaging of results to only a group of elements that are considered to be bound by same feature angle or face.
HyperView allows for plotting (contour, iso, vector, or tensor) across multiple overlaid models.
The fatigue manager allows you to write stress and strain results from a finite element analysis to an external file that can be used to set up a fatigue analysis.
The fatigue configuration file is a user-defined external ASCII-file through which the data groups from results of static/modal/transient analysis of different solvers can be read.
A new workflow emphasizing upfront data loading for standard crash post processing use cases.
Figure 1. © 2023 Altair Engineering, Inc. All Rights Reserved.
