Create Plot Style
                From the Plot tools, click the Contour tool.
                 Figure 1. Figure 1.
                From the Contour panel, click the Create Plot Style
                    button.
                The Create/Update Contour Plot Style dialog opens, which allows you to create or update a result plot style based on the current settings of the contour.Note: A contour plot needs to be current in order to create a new style or modify an existing one.All the settings of the contour plot (corner data options, averaging, resolved in systems, default data type/components, display options, legend, etc.) are captured in the named style.
