Overlay Result Display
                From the Plot tools, click the Contour tool.
                 Figure 1. Figure 1.
                From the Contour panel, under Result display control, activate the
                        Overlay result display option.
                Overlays the vector, tensor, and contour results in the same window.Note: If all results are displayed simultaneously, available memory may be affected.
