Material Summary
- Material Isotropic MAT1 Details
- Material Isotropic MAT4 Details
- Material Anisotropic MAT2 Details
- Material Orthotropic MAT8 Details
- Right-click at the report or chapter level and select .
                Make your selections.
View new features for HyperWorks 2022.2.
Create an assembly structure from a .csv file definition.
A powerful tool for manual/automatic report creation using the model summary report template (.tpl) file. This tool provides a simplified and consolidated approach for report creation with one click and by define your own report structure.
Modules are used to perform specific operations in a report in automated ways and provide the output in the prescribed format per module logic.
Select export and module settings.
Capture a dynamic view of the model, including display options.
