Part Summary
- Component High level Info
- Component with Min Max ID Details
- Component Mass Highlights
- Component COG Data
- Component MOI Data
View new features for HyperWorks 2022.2.
Create an assembly structure from a .csv file definition.
A powerful tool for manual/automatic report creation using the model summary report template (.tpl) file. This tool provides a simplified and consolidated approach for report creation with one click and by define your own report structure.
Modules are used to perform specific operations in a report in automated ways and provide the output in the prescribed format per module logic.
Select export and module settings.
Capture a dynamic view of the model, including display options.
ON THIS PAGE
ON THIS PAGE
