Model Summary
A powerful tool for manual/automatic report creation using the model summary report template (.tpl) file. This tool provides a simplified and consolidated approach for report creation with one click and by define your own report structure.
This report covers the following aspects related to the model:
                        - Isometric view
- Top view
- Front view
- Left-side view
- Pre-defined
- Global Model Summary- Entire model high level entity count
- Entire model units
- Entire model mass information
- Entire model MOI using COG as center
- Entire model COG information
- Part Summary- Component high level information
- Component with min max ID details
- Component mass highlights
- Component COG data
- Component MOI data
- Material Summary- Material isotropic MAT1 details
- Material isotropic MAT4 details
- Material anisotropic MAT2 details
- Material orthotropic MAT8 details
- Property Summary- Property information with type and ID
- Elements Summary- Elements 1D count
- Elements 2D 3D count
- 2D mesh quality statistics table
- 2D mesh quality statistics plot
- 3D mesh quality statistics table
- 3D mesh quality statistics plot
- Ply Orientation- Information of model
- Model thickness in mm plot
- Model material and property IDs and plies "0°, 45°, -45°, 90°"
- Shell Summary- Information of model
- Entire model shell thickness summary
- Model Checker Summary- Model Checker ERROR table
- Model Checker WARNING table
- Model Checker INFO table
- Failed Checks tables
- Model Checker Plots- Component with solids and shells
- Orientation vector along axis vector
- RBE3 elements are collinear
- Duplicate 1D/2D/3D elements
- Free nodes in the model
- Coinciding G1 and G2 grid points
- Element Quality Plots- Aspect ratio 2D/2D
- Chordal deviation 2D
- Coordinate systems
- Free edges
- Free faces
- Normal
- Element offset 1D
- Element coordinate system
- Node coordinate system
- Jacobian 2D/3D
- Volume aspect ratio 3D
- Interactive Mode
- The Report Browser is used to create, execute and export document and presentation reports.
- Default Mode
- Generate pre-defined model summary report.
- Model Checker Report
- Define report group enables you to perform report actions with one click.
- Aerospace Model Summary Report Modules
- Modules are used to perform specific operations in a report in automated ways and provide the output in the prescribed format per module logic.
- Preferences
- Modify the main document and select the report template.
- Custom Tasks
- Custom tasks in report generation.
- Record View Tool
- Dynamic image capture tool.
