ACIS Reader
Supported Entities
- Coordinate systems
- Free points
- Free curves
- Surfaces
- Quilt bodies
- Solid bodies
Import Options
| Value | Description |
| on | Import all generic attributes (global and related to single entities) as metadata. |
| off | Do not import attributes related to single entities. Only import global attributes. |
| %attribute1%attribute2%attribute3 | Import specified generic attributes as metadata. The attribute names are listed, separated by a character that you choose, and inserted as the first element of the string. The example uses '%' as a separator. You can choose another character as a separator, in case one of the listed attribute names contains '%'. HyperWorks will recognize it as it is the first character of the string. |
| on | Avoid using the conversion functions provided by third-party (default). |
| off | Use the conversion functions provided by third-party. |
| on | Assign body identifier as
                metadata.
| off | Do not assign body identifier as metadata (default). |
| double | A negative value (default) indicates to use the auto cleanup tolerance. A value greater than the calculated auto cleanup tolerance indicates to use that specific tolerance. Refer to the CAD Cleanup Tolerance. |
| integer | Read color attributes of geometric entities as metadata with integer values.
| on | Read color attributes of geometric entities as metadata.
| off | Do not read color attributes (default). |
| Parts | Generate a full part-based hierarchy. |
| BOMOnly | Generate an empty part-based hierarchy. |
| TreeOfComponents | Generate an assemblies/components based hierarchy. |
| PackIntoSinglePart | Consolidate hierarchy into a single part. |
| on | Read density value as metadata (default).
| off | Do not read density value. |
| on | Preserve the original geometry edges, instead of merging them together during the import cleanup phase. |
| off | Merge edges together during the import cleanup phase (default). |
| on | Import entities that are hidden, blanked, or no show. |
| off | Do not import entities that are hidden, blanked, or no show (default). |
| on | Import CAD coordinate systems as system collectors (default). |
| off | Do not import CAD coordinate systems. |
| on | Import the model for visualization purposes only. This skips many of the import steps (cleanup, stitching, solid creation, and so on) to provide a faster import. The resulting model may not be suitable for other uses. |
| off | Import the model in the normal fashion (default). |
| on | Import free curves (wireframe entities) into the model (default). |
| off | Do not import free curves. |
| on | Import free points into the model (default). |
| off | Do not import free points. |
| on | Read layer value as metadata.
| off | Do not read layer value (default). |
| on | Generate metadata with the original CAD hierarchy within the
                part.
| off | Do not generate metadata with the original CAD hierarchy within the part (default). |
| string | The string is prefixed to all metadata names. No prefix is used by
                  default. See CAD Metadata Naming for more details. |
| on | Import original CAD entity IDs as
                metadata.
| off | Do not import original CAD entity IDs as metadata (default). |
| double | Define the model scaling factor during import. Default is 1.0. |
| on | For trimmed surfaces, shrink the corresponding base surfaces to only enclose the extents of the external trimming contour, plus a narrow frame. |
| off | Do not modify the base surfaces (default). |
| on | Read surfaces, but do not create solid entities. |
| off | Create solid entities (default). |
| Body | Generate body-based component (default if CreationType=Parts). |
| Layer | Generate layer-based component. |
| Part | Generate part-based component. |
| General | Keep component as in CAD (default if CreationType=TreeOfComponents). |
| on | Stitch surfaces belonging to different components. |
| off | Do not stitch surfaces belonging to different components (default). |
| on | Use the Parasolid reader to read embedded XT breps (default). |
| off | Also use the standard JT reader to read XT breps. |
| CAD units | Keep the units of the CAD files (default for GUI). |
| MKS [m kg N s] | Convert to the corresponding units system. |
| MMKS [mm kg N s] | Convert to the corresponding units system. |
| MPA [mm t N s] | Convert to the corresponding units system. |
| CGS [cm g dyn s] | Convert to the corresponding units system. |
| MMKNMS [mm kg kN ms] | Convert to the corresponding units system. |
| MMGNMS [mm g N ms] | Convert to the corresponding units system. |
| IPS Std [in pounds lbf s] | Convert to the corresponding units system. |
| IPS Grav [in slinch lbf s] | Convert to the corresponding units system. |
| FPS Std [ft pounds lbf s] | Convert to the corresponding units system. |
| FPS Grav [ft slug lbf s] | Convert to the corresponding units system. |
| Scale factor | Apply the corresponding scale factor (default for no GUI to allow supporting legacy scripts). |
Supported Metadata
| Type | Entities | Description |
| string |
 | Identifier of the CAD body containing the entity. Generated when
| string | comps, assems if hierarchy as Assemblies; parts if hierarchy as Parts | Three RGB values, ranging from 0 to 255, indicating the color of the entity in the CAD model. Generated when  |
| double | solids | The value of the density of a solid. Generated when  |
| integer |
 | Value of the layer of an entity. Generated when
| string |
 | Hierarchy of an entity within a part. Generated when
| integer | comps if hierarchy as Assemblies; parts if hierarchy as Parts | Model units specified in the CAD file.
 This is always generated. |
| ORIGINAL_ID |
 | The original CAD entity ID. Generated when  |
