DXF Reader
Supported Entities
- Free points (POINT)
- Free curves (LINE)
- Surfaces (3DFACE)
- Solid (SOLID)
- Facets/triangles (POLYLINE with Group Code 70=64 for polyface mesh)
Import Options
| Value | Description |
| on | Assign body identifier as
                metadata.
| off | Do not assign body identifier as metadata (default). |
| double | A negative value (default) indicates to use the auto cleanup tolerance. A value greater than the calculated auto cleanup tolerance indicates to use that specific tolerance. Refer to the CAD Cleanup Tolerance. |
| integer | Read color attributes of geometric entities as metadata with integer values.
| on | Read color attributes of geometric entities as metadata.
| off | Do not read color attributes (default). |
| Parts | Generate a full part-based hierarchy. |
| BOMOnly | Generate an empty part-based hierarchy. |
| TreeOfComponents | Generate an assemblies/components based hierarchy. |
| PackIntoSinglePart | Consolidate hierarchy into a single part. |
| on | Generate metadata with the original CAD hierarchy within the
                part.
| off | Do not generate metadata with the original CAD hierarchy within the part (default). |
| string | The string is prefixed to all metadata names. No prefix is used by
                  default. See CAD Metadata Naming for more details. |
| double | Define the model scaling factor during import. Default is 1.0. |
| Part | Generate part-based component (only allowed value if CreationType=Parts). |
| General | Keep component as in CAD (only allowed value if CreationType=TreeOfComponents). |
| CAD units | Keep the units of the CAD files (default for GUI). |
| MKS [m kg N s] | Convert to the corresponding units system. |
| MMKS [mm kg N s] | Convert to the corresponding units system. |
| MPA [mm t N s] | Convert to the corresponding units system. |
| CGS [cm g dyn s] | Convert to the corresponding units system. |
| MMKNMS [mm kg kN ms] | Convert to the corresponding units system. |
| MMGNMS [mm g N ms] | Convert to the corresponding units system. |
| IPS Std [in pounds lbf s] | Convert to the corresponding units system. |
| IPS Grav [in slinch lbf s] | Convert to the corresponding units system. |
| FPS Std [ft pounds lbf s] | Convert to the corresponding units system. |
| FPS Grav [ft slug lbf s] | Convert to the corresponding units system. |
| Scale factor | Apply the corresponding scale factor (default for no GUI to allow supporting legacy scripts). |
Supported Metadata
| Type | Entities | Description |
| string |
 | Identifier of the CAD body containing the entity. Generated when
| string |
 | Hierarchy of an entity within a part. Generated when
