VDAFS Reader
Supported Entities
- POINT
- LINE
- PLANE
- PSET
- MDI
- CIRCLE
- CURVE
- SURF
- FACE
Import Options
| Value | Description |
| double | A negative value (default) indicates that the curves are being split at C1
                  discontinuities. A positive value indicates that curves are being split at G1 discontinuities with an angle greater than the given value (expressed in radians). |
| double | A negative value (default) indicates to use the auto cleanup tolerance. A value greater than the calculated auto cleanup tolerance indicates to use that specific tolerance. Refer to the CAD Cleanup Tolerance. |
| Parts | Generate a full part-based hierarchy. |
| BOMOnly | Generate an empty part-based hierarchy. |
| TreeOfComponents | Generate an assemblies/components based hierarchy. |
| PackIntoSinglePart | Consolidate hierarchy into a single part. |
| on | Preserve the original geometry edges, instead of merging them together during the import cleanup phase. |
| off | Merge edges together during the import cleanup phase (default). |
| on | Import the model for visualization purposes only. This skips many of the import steps (cleanup, stitching, solid creation, and so on) to provide a faster import. The resulting model may not be suitable for other uses. |
| off | Import the model in the normal fashion (default). |
| on | Import free curves (wireframe entities) into the model (default). |
| off | Do not import free curves. |
| on | Import free points into the model (default). |
| off | Do not import free points. |
| on | Generate metadata with the original CAD hierarchy within the
                part.
| off | Do not generate metadata with the original CAD hierarchy within the part (default). |
| string | The string is prefixed to all metadata names. No prefix is used by
                  default. See CAD Metadata Naming for more details. |
| Any positive real number. | The reader considers this tolerance as the parametric tolerance used to process the CAD data. The default value is 1.00E-06. |
| on | Treat each surface as found in the CAD file (planes/NURBS). |
| off | Convert planes into NURBS surfaces. |
| preferred | Convert NURBS surfaces to planes if they are within the object space tolerance of being planar (default). |
| double | Define the model scaling factor during import. Default is 1.0. |
| Body | Generate body-based component (default if CreationType=Parts). |
| Part | Generate part-based component. |
| General | Keep component as in CAD (default if CreationType=TreeOfComponents). |
| Components | Generate JT component-based components. |
| on | Treat each polynomial segment as a straight line segment. This is necessary for reading some VDAFS files, COMPUTERVISION CADDS 4X in particular. |
| off | Treat each polynomial as found in the CAD file (default). |
| on | Read tags of supported entities as metadata (default).
| off | Do not read tags. |
| CAD units | Keep the units of the CAD files (default for GUI). |
| MKS [m kg N s] | Convert to the corresponding units system. |
| MMKS [mm kg N s] | Convert to the corresponding units system. |
| MPA [mm t N s] | Convert to the corresponding units system. |
| CGS [cm g dyn s] | Convert to the corresponding units system. |
| MMKNMS [mm kg kN ms] | Convert to the corresponding units system. |
| MMGNMS [mm g N ms] | Convert to the corresponding units system. |
| IPS Std [in pounds lbf s] | Convert to the corresponding units system. |
| IPS Grav [in slinch lbf s] | Convert to the corresponding units system. |
| FPS Std [ft pounds lbf s] | Convert to the corresponding units system. |
| FPS Grav [ft slug lbf s] | Convert to the corresponding units system. |
| Scale factor | Apply the corresponding scale factor (default for no GUI to allow supporting legacy scripts). |
| Any positive real number. | The reader considers this tolerance as the object space tolerance used to process the CAD data. The default value is 0.01. |
Supported Metadata
| Type | Entities | Description |
| string |
 | Hierarchy of an entity within a part. Generated when
| string | points lines surfs | The tag (name) of the entity as read from the CAD model, if one exists. Generated when  |
