LA Card
With this card, labels are assigned to segments, triangles, polygonal plates, cuboids, uniform theory of diffraction cylinders and points.
On the Home tab, in the Define group, click
the Label (LA) icon.
![](../../../../../../images/feko/user_guide/editfeko_cards/dialog_la.png)
Figure 1. The LA - Assign labels dialog.
Parameters:
- Label for following geometry
- The label assigned to all geometry, for example, segments, triangles and tetrahedra defined in cards following this card.
All elements created after the LA card (by for example the BP card), are assigned the value or string specified label of the dialog. A different label is only assigned by a new LA card. All structures created before the first LA card (or if no LA card is present), is assigned the default label which is 0 (number zero).
Label names can be an arbitrary string using the characters A-Z, the digits 0-9 or also the underscore _. Labels may be manipulated using label increments and referenced using label ranges.
