Adds a new rake to the CFD Plot/Streamlines panel.
Creates streamlines for the specified rakes based on the current settings in the CFD Plot/Streamlines panel.
Deletes the specified rake from the CFD Plot/Streamlines panel.
Deletes the streamlines for the rakes specified in the CFD Plot/Streamlines panel.
Returns the data type that was used for the streamline creation in the CFD Plot/Streamlines panel.
Returns the integration method that was used for the streamline creation in the CFD Plot/Streamlines panel.
Returns the threshold value for the break angle between two neighboring streamline segments, which is used to decide if the two line segments should be merged into one, or kept untouched.
Returns the maximum integration step length in the CFD Plot/Streamlines panel.
Returns the number of colors in the color map that were used to color the individual streamlines in the CFD Plot/Streamlines panel (when the 'color-by mode' is set to "seed").
Returns the handle of the rake specified by the rake_id.
Returns a list of rake IDs from the CFD Plot/Streamlines panel.
Returns the 'colored-by mode' of the streamlines in the CFD Plot/Streamlines panel.
Returns whether decimation is being applied to streamlines in the CFD Plot/Streamlines panel, in order to reduce the memory footprint.
Returns the size of the streamlines in the CFD Plot/Streamlines panel.
Returns the style of the streamlines in the CFD Plot/Streamlines panel.
Sets the data type used for the streamline creation in the CFD Plot/Streamlines panel.
Specifies the integration algorithm used for the streamline creation in the CFD Plot/Streamlines panel.
Specifies the threshold value for the break angle between two neighboring streamline segments, which is used to decide if the two line segments should be merged into one, or kept untouched.
Specifies the maximum integration step length in the CFD Plot/Streamlines panel.
Specifies the number of colors in the color map used to color the individual streamlines in the CFD Plot/Streamlines panel (when the 'color-by mode' is set to "seed").
Specifies the 'colored-by mode' of the streamlines in the CFD Plot/Streamlines panel.
Specifies whether decimation should be applied to the streamlines in the CFD Plot/Streamlines panel, in order to reduce the memory footprint.
Specifies the size of the streamlines in the CFD Plot/Streamlines panel.
Specifies the style of the streamlines in the CFD Plot/Streamlines panel.
Specifies the criterion for integration termination in the streamline creation in the CFD Plot/Streamlines panel.
ON THIS PAGE
ON THIS PAGE
