Adds the layer to the layer filter.
Gets the base data type layer list in the layer filter.
Gets the description of the layer filter.
Gets the ID of the layer filter.
Gets the label of the layer filter.
Gets the layer list in the layer filter.
Gets the data type from which the layer filter has been created.
Gets the subcase ID with which the layer filter has been created.
Verifies if the given layer is present in the layer filter.
Removes all layers from the layer filter.
Removes the layer from the layer filter.
Sets the description for the layer filter.
Sets the label for the layer filter.
