Returns the ID of the rake in the CFD Plot/Streamlines panel.
Returns the integration mode for the rake in the CFD Plot/Streamlines panel.
Returns the label of the rake in the CFD Plot/Streamlines panel.
Returns the number of the seeds in the rake used for the stream integration creation in the CFD Plot/Streamlines panel.
Returns the definition string of the rake in the CFD Plot/Streamlines panel.
Returns the type of the rake in the CFD Plot/Streamlines panel.
Specifies the integration mode for the rake in the CFD Plot/Streamlines panel.
Sets the label of the rake in the CFD Plot/Streamlines panel.
Specifies the number of the seeds in the rake used for the stream integration creation in the CFD Plot/Streamlines panel.
