HMMOD_elementgetcentroidalresult()
Retrieves the centroidal result of an element specified by element pointer, layer, and index.
float HMMOD_elementgetcentroidalresult(void * elementptr, int layer, int index);
HyperMesh hmmodlib Function
elementptr
The pointer to the element.
layer
The layer where the centroidal result is stored.
index
The index to the array of centroidal results.
The result at the centroid of the specified element.
None.
