HMMOD_nodegetdisplacement()
Retrieves the displacement values of the node specified by the node pointer.
void HMMOD_nodegetdisplacement(void * nodeptr, float * x, float * y, float * z);
HyperMesh hmmodlib Function
nodeptr
The pointer to the node.
x
The displacement value at the x coordinate.
y
The displacement value at the y coordinate.
z
The displacement value at the z coordinate.
The values of the x, y, and z variables are set to the displacement values of the specified node.
None.
