HMMOD_nodegetresult()
Retrieves the nodal result of the node specified by the node pointer, layer, and index.
float HMMOD_nodegetresult(void * nodeptr, int layer, int index);
HyperMesh hmmodlib Function
nodeptr
The pointer to the node.
layer
The layer where the nodal result is stored.
index
The index of nodal results.
The nodal result at the specified node.
None.
