HMMOD_elementgetnodeonelementresult()
Retrieves the node-on-element result of an element specified by element pointer, layer, node index, and index.
float HMMOD_elementgetnodeonelementresult(void * elementptr, int layer, int nodeindex, int index);
HyperMesh hmmodlib Function
elementptr
The pointer to the element.
layer
The layer where the node-on-element point result is stored.
nodeindex
The node-on-element point where the result is stored.
index
The index to the array of node-on-element point results.
The result at the node-on-element point of the specified element.
None.
